975760
TattooedYorkie
September 29, 2024, 10:30 AM
New School BMX 2004 - Now
headset headache please help
Topic: headset headache please help (Read 1040 times)
endo
August 31, 2010, 09:31 PM »
hi guys trying to fit a new eclat head set to a 2009 united 40 with 2000ish pitchforks and cant seem to stop movement, if i tighten the preload bolt to stop the movement then you can hardly move the bars, getting the hump with it any ideas
motomagII
Re: headset headache please help
August 31, 2010, 09:34 PM »
best bet is to put pic up of easch part as assembled see if we can spot owt
mm is it aheaad or internal
endo
August 31, 2010, 09:53 PM »
its internal and i have fitted loads before just cant sort this one out ,need about 20mm of spacers on top but that should noit cause a problem
BrianP
Cherry Picker
August 31, 2010, 09:58 PM »
hi mate does the movement seem like it's at the top of the headtube or the bottom (can you even maybe see it?)
did the eclat come with a bottom race for dropping onto your pitchforks?
as greg says, get some pics up?
Brian
endo
August 31, 2010, 10:01 PM »
cheers guys ,i have fitted the race supplied to the forks and that bit is all smooth it all seems tro be down to the preload bolt . will try and put some pics on but that is a rite faf with photo bucket and all that
madmike-bmx
August 31, 2010, 10:06 PM »
dude ,,, maybe ur useing an unsealed race ... or stick some grease on the bearings ... might seem stupid but it dose work a lot btetter and makes it a bit smoother as well :L
endo
August 31, 2010, 10:14 PM »
cheers guys, the race is the 1 that came with the new sealed headset ,have just put it together a bit tight for now which has stopped movement but wiil grease it all up tomorow and put it all back together tight and maybe it will loosen up with a bit of shredding ,will keep you all posted on the outcome ,thanks for the help
muttley
September 02, 2010, 05:14 PM »
I had this today after refitting my headset, i had basically left a little bit on the floor that fits in the bearing to stop movement, its a split ring that fits right into the bearing
