975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 04:46 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  headset headache please help
Author Topic: headset headache please help  (Read 503 times)
endo
« on: August 31, 2010, 09:25 PM »
hi guys trying to fit a new eclat intergrated headset to a 2009 united 40 frame with some 2000ish pitch forks and just cant seem to stop movement ,if i tighten the preload bolt so there is no movement then you can hardly turn the bars any ideas  cheers :D
HEYWOOD BMX
Re: headset headache please help
« Reply #1 on: September 01, 2010, 12:34 AM »
 :) Do you have enough stem spacers? Sometimes adding a 1 or 3mm spacer will solve the problem..
ozone
« Reply #2 on: September 01, 2010, 08:57 AM »
You haven't put a bearing in the wrong way up have you?  Sounds daft but is easily done.  ;D
