975926 Posts in 138954 Topics by 6389 Members - Latest Member: The Docmeister April 18, 2025, 10:35 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tuff coaster question
Author Topic: Tuff coaster question  (Read 1148 times)
« on: August 27, 2010, 11:15 AM »
right i need to give my rear coaster Tuff a regreasing but my question is this, if i take out the axle will all the coaster internals fall in on themselves or will it allow me to just take out the bearings to clean and regrease?
moley
Re: Tuff coaster question
« Reply #1 on: August 27, 2010, 11:44 AM »
Dont worry, Just take it all apart its easy to get back together again!!
Theres not much to them apart from the feckin bearings which like to escape
moley
« Reply #2 on: August 27, 2010, 11:49 AM »
It will be similar in design to this except the bearings wont have a retainer (loose ball).............or at least they didn't on my OS Skyway coaster Tuff II
When you reassemble  then pack a load of grease on the bottom bearing run and stick your bearings in it then run the axle fully through so the bearings can't escape then place the axle on the floor/desk etc, etc so the axle stays put and then the other side just drop the bearings past the axle which will have loads of play because the hub externals haven't been screwed down yet.
Just make sure your pawls are the right way around and aligned.  If they aren't then you wont be able to fit it.  So you'll know when you've done it right because it fit!!
« Last Edit: August 27, 2010, 11:56 AM by moley »
« Reply #3 on: August 27, 2010, 12:59 PM »
cheers Moley!   :daumenhoch:   might have a bash at the weekend while it's p*ssing down outside
« Reply #4 on: August 27, 2010, 01:14 PM »
Good stuff Moley, been looking for those scans for a while  :daumenhoch:
