975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 08:02 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Std 1" Threaded headset query - Headtube Internal Diameter
Author Topic: Std 1" Threaded headset query - Headtube Internal Diameter  (Read 842 times)
Offline BrianP
Okay, maybe someone knows this off the top of their head :)
For a regular 1" BMX headset, what is the inside diameter of the head tube where the cups push in, or alternatively what is the outside diameter of the part of the bearing cup which pushes into the head tube?
Thanks,
Brian  :daumenhoch:
Re: Std 1" Threaded headset query - Headtube Internal Diameter
« Reply #1 on: August 18, 2010, 05:28 PM »
brian is this for a dragon fly frame as the 1" std headset wont fit
Rodgy1970
« Reply #2 on: August 18, 2010, 06:03 PM »
Offline BrianP
« Reply #3 on: August 18, 2010, 07:22 PM »
Not this time Dan, this is for another project, but you have made me curious now about my dragonflys  ;D
Must have a look at the weekend.
might be of use to you
http://sheldonbrown.com/headsets.html
And thanks for the link Rodgy, that's a good bit of reading. Have bookmarked the link ;)
Brian  :daumenhoch:
Offline Gary72
« Reply #4 on: August 18, 2010, 11:00 PM »
Think there's something on the Chris King website. I have a couple of 1 inch Odyssey Pro headset's that have to have a shim to fit NORMAL bmx bikes. Some mini's run a smaller diameter headtube like older roadbike's.
