975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 04:51 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Deacals
Author Topic: Deacals  (Read 654 times)
Offline tobytyke
Deacals
« on: July 17, 2010, 06:45 PM »
Applied decals to my build following the link on the forum, in daylight though i have noticed a couple of air bubbles still  :( , is there  any tips for safely removing them so i can reapply   :daumenhoch:
Re: Deacals
« Reply #1 on: July 17, 2010, 07:00 PM »
its too late now.... :(
Re: Deacals
« Reply #2 on: July 17, 2010, 07:01 PM »
Try warming them up with a hairdryer - makes em easier to peel off  :daumenhoch:
ozone
Re: Deacals
« Reply #3 on: July 17, 2010, 09:02 PM »
I used to burst the bubbles with a pin when I was a kid.   ;D
Re: Deacals
« Reply #4 on: July 17, 2010, 09:21 PM »
id perhaps try and gently heat them up with a hairdryer and try and chase the bullble out by pushing them to the edges of the decal  :)
Offline southern andy
Re: Deacals
« Reply #5 on: July 18, 2010, 07:47 AM »
You may have to do what Ozone suggested.
Get the thinnest pin you can find and just touch the bubble lightly so it pierces a minute hole then press the decal down. The air will escape out the hole and your decal will stick. try piercing it where it will be less seen.
I'd be very surprised if you saw the hole after that.
A hair dryer heating the sticker up to remove again will probably only stretch the vinyl, its defo shagged then.
