975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 03:10 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Old school skyway sprocket - how do I get it off?
Author Topic: Old school skyway sprocket - how do I get it off?  (Read 4512 times)
Offline fischflo
Re: Old school skyway sprocket - how do I get it off?
« Reply #25 on: July 17, 2010, 09:55 PM »
weld done
Offline sawzall
« Reply #26 on: July 17, 2010, 09:58 PM »
now you have it back together this is the best way to remove it,tack weld a piece
of bar across freewheel making sure it won't turn,then use bar as lever and freewheel will come off,
do it while it's still hot as this will help it  ;)
forgot to say make sure wheel is covered up when welding as weld splatter will stick to wheel :(
Offline fischflo
« Reply #27 on: July 17, 2010, 11:24 PM »
....meanwhile at the workshop
Plinth Adenoid
« Reply #28 on: July 18, 2010, 12:00 AM »
Lol, love the pic! I take it it's a left handed thread and I'm basically taking the while thing off the same thread the race goes onto?
Offline fischflo
« Reply #29 on: July 18, 2010, 01:07 AM »
".........6. The inner body is threaded clockwise onto the hub shell. Look on inner body for two flats created by pawls. Grab the body firmly on these flats in a vise and turn wheel counter-clockwise.  ................."             (http://www.parktool.com/repair/readhowto.asp?id=46)
Plinth Adenoid
« Reply #30 on: July 18, 2010, 04:58 PM »
Thanks everyone, the buggers off and I only skinned my pinky (finger). I took the cog of, popped the mole grips on the bottom race, put that into the work bench, turned clockwise and squashed my finger. I then threw away the crappy one and now perusing replacements on flea bay.
Thanks all for your help, especially sawzall, fischflo and moose. Moose, I saw your sig once state "Trust Moose", I did and all was good.  ;D
Offline fischflo
« Reply #31 on: July 18, 2010, 09:36 PM »
lolol     .................. "gettin it loose with Moose"
