975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 25, 2024, 10:22 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  coaster brake to free coaster help PROBLEM SOLVED
Author Topic: coaster brake to free coaster help PROBLEM SOLVED  (Read 1500 times)
kidclyde
« on: July 16, 2010, 12:38 PM »
i took the brake pads out but i dont know how to get rid of the slack when you pedal back
btw its on one of the modern coaster brake skyways
I FIXED IT THANKS
« Last Edit: July 17, 2010, 10:04 AM by kidclyde »
Online brettypeeps
Re: coaster brake to free coaster help
« Reply #1 on: July 16, 2010, 12:54 PM »
Not sure what you are getting at...
1. What have you done?
2. What were you trying to achive?
3. What is the problem now?
kidclyde
« Reply #2 on: July 16, 2010, 01:05 PM »
1. What have you done? - i took the pads out of the coaster brake
2. What were you trying to achive? - a free coaster
3. What is the problem now? - there is slack in the chain
thanks
moley
« Reply #3 on: July 16, 2010, 01:06 PM »
I think you stick some washers on it so that it can't unscrew that far back!!  :daumenhoch:
Offline BrianP
« Reply #4 on: July 16, 2010, 01:18 PM »
Yep, washers needed to take up the slack ;)
http://www.wtlw.net/ff/suntour/
Brian  :daumenhoch:
Online brettypeeps
« Reply #5 on: July 16, 2010, 01:35 PM »
And it all makes perfect sense now  :daumenhoch: as the guys said washers  8)
Offline SteveG
« Reply #6 on: July 16, 2010, 01:41 PM »
The only trouble is that without the shoes there isn't any drag to make the cone lock up. I haven't tried it but is there a chance that the cone won't lock reliably ? I have a feeling a friend did a similar thing but fitted a spring somewhere to keep the cone in contact with the freewheel part.
As I say, haven't tried it but wouldn't want anyone to experience what would be similar to Sturmey Archer gear slip at the wrong moment  ;)
