975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 05:25 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  CRANK SIZING?
Author Topic: CRANK SIZING?  (Read 930 times)
HEYWOOD BMX
CRANK SIZING?
« on: July 09, 2010, 11:04 AM »
 :) I`m currently running 175mm cranks,44/16 and 1.5 tyres.If I run 170mm cranks instead,will it feel much different?
Re: CRANK SIZING?
« Reply #1 on: July 09, 2010, 01:18 PM »
It wont feel much different but your starts may be a bit slower after all you are losing 5mm leverage off each crank arm.   :daumenhoch:
Re: CRANK SIZING?
« Reply #2 on: July 09, 2010, 02:30 PM »
get some of those ultra thin pedals n yul get the 5mm back
Offline Jon The Bassist
Re: CRANK SIZING?
« Reply #3 on: July 09, 2010, 03:00 PM »
 :LolLolLolLol: - Daz
James, it'll gave the same effect as if you very slightly increased your gear ratio. So, in theory you'll have less leverage (worse for starts) but you have less distance to turn the pedals giving you a slightly higher cadence (better for top speed). Overall not likely to change you lap times much (if at all).
HEYWOOD BMX
Re: CRANK SIZING?
« Reply #4 on: July 09, 2010, 05:56 PM »
  Already got`em-Superstar Nanos :daumenhoch:
