975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 06:37 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Removing dia compe brake rub from lavvy tuffs
Author Topic: Removing dia compe brake rub from lavvy tuffs  (Read 707 times)
Offline aerostylie
« on: July 08, 2010, 08:32 PM »
Just attempting to tidy up the tuffs from the weekends ride, and is taking an age to get rid of the brake rub.
I've been using a stanley knife blade (very carefully) to lift off any that I can, then using astonish oven cleaner (light abrasive) with water, to remove any access, making sure I don't discolour the tuff.
This is the result thus far  ;D .....its a start!
Are there any other quick methods for removing the brake rub, as you can see I have a way to go, then the other side and then the other wheel, or shall I stick with what I'm doing and be patient?
Paul
« Last Edit: July 08, 2010, 08:49 PM by aerostylie »
Vans Style
Re: Removing dia compe brake rub from lavvy tuffs
« Reply #1 on: July 08, 2010, 09:11 PM »
I think you're doing it the right way paul, its a ball ache mate which is why I wouldn't use dark pads on em to begin with.  I've got some baby blue tuff pads you can have mate if that's any good to you?
I'll bring em to MK
Offline aerostylie
« Reply #2 on: July 08, 2010, 09:18 PM »
I'll bring em to MK
Yeah deffo ball and finger ache Rob, they were minty tuffs as well.
No worries re the pads though, I've got some purple tuff pads........but didn't use em up front, doh :crazy2:
Lesson learned!
« Last Edit: July 08, 2010, 09:22 PM by aerostylie »
Vans Style
« Reply #3 on: July 09, 2010, 07:59 AM »
I used 2000 grit wet and dry papaer to remove the black brake rub from my yellow tuffs.
