975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 05:27 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Stuck spocket nut
Author Topic: Stuck spocket nut  (Read 1292 times)
Offline skki3330
  • Love Riding Old Bikes
Stuck spocket nut
« on: July 05, 2010, 01:23 PM »
Grrrrr everything seems to be welded at the mo lol
Ok i have a Suntour sprocket on a sun shine hub and i can t get the frikkin sprocket nut off.
Just to make sure in not turning the incorrect way im going clockwise, surely you can remove this??? just asking never had sun shine hubs before.
WANTED
SE Powerwings
Holeshot RF-1
Re: Stuck spocket nut
« Reply #1 on: July 05, 2010, 03:28 PM »
Eighty tighty lefty loosy.  Should be th way it freewheels or standard thread :daumenhoch:
Offline oldtired
  • Dirty Old Man
« Reply #2 on: July 05, 2010, 04:48 PM »
"  Righty tighty Lefty loosy "      :LolLolLolLol:    i like that  :daumenhoch:
Offline skki3330
« Reply #3 on: July 05, 2010, 06:51 PM »
Tried lefty loosey and then i thought id try righty tighty and guess what...........................................................................still wont budgie wudgie grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr i even give it a little heat and broke a bloody sprocket tooth in the process!!!! now i have the arse need this hub to finish my build.
Any Ideas???
WANTED
SE Powerwings
Holeshot RF-1
« Reply #4 on: July 05, 2010, 07:45 PM »
clamp the free wheel in the vice and use the wheel as your lever.  If you tighten it enough you free wheel wont rotate and eh voila!!! you should be there if that fails try your LBS (local Bike Shop) they will have a trick or two :daumenhoch:
Offline skki3330
« Reply #5 on: July 05, 2010, 08:24 PM »
Thats what i done to start with and the spokes started to bend the rim soooo i stopped.
Yeah can run it done my local bike rip off merchants lol.
WANTED
SE Powerwings
Holeshot RF-1
« Reply #6 on: July 05, 2010, 09:56 PM »
OOOHH lah angle grinder time then I reckon on that but take your time not to damage the hub and wear some goggles as the bearings can come out at some pace.  give it a good soak in 3 in 1 oil or WD40 while doing it to keep the temperature down :daumenhoch:
Offline oldtired
  • Dirty Old Man
« Reply #7 on: July 05, 2010, 10:28 PM »
get the toothy woothy bit off, inside there'll be a couple of dinty winty's where the pawly wallie or ratchety cratchety bit fits , use something that fits the dint winty you should be able to loosen it with a good shocky woky , i don't mean show it the twig and berries either, :LolLolLolLol: , load of wd40 and a heavy hammer bammer , anti clock wise with the freewheel  facy wacying you  , if it don't budgie wudgie after that then your fooktie wookty  :LolLolLolLol:
« Reply #8 on: July 05, 2010, 10:47 PM »
:LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol:
Offline skki3330
« Reply #9 on: July 06, 2010, 08:21 PM »
 :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol:
Taking down the biky wiky shop tomorrow done my heady weady in!
WANTED
SE Powerwings
Holeshot RF-1
« Reply #10 on: July 06, 2010, 08:54 PM »
 :2funny:  :2funny:  :2funny: Pissey funney
Offline skki3330
« Reply #11 on: July 08, 2010, 07:00 PM »
Thats it i wernt messing anymore took the fookin grinder to it grrrrrrrrrrrrrrrrrrrrrrrrrrrrr yeah soon come off. now i can get on with my wheel build for my partners viper for the 5th sep :P
WANTED
SE Powerwings
Holeshot RF-1
« Reply #12 on: July 08, 2010, 08:50 PM »
grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr  8) ;D :LolLolLolLol: :LolLolLolLol:
Job Done :LolLolLolLol: :LolLolLolLol: :LolLolLolLol:
