975755
TattooedYorkie
September 22, 2024, 01:32 AM
alloy hub skyway removal
Topic: alloy hub skyway removal (Read 1864 times)
arbor-aero
June 12, 2010, 06:35 AM »
can any body direct me into;-
1. removing the free wheel, as it is stuck on and i do not have the tool (should i purchase !)?
2. remove the alloy star.
3. refitting the alloy star.
4. any kits, equipment and tools i will require.
cheers adrian
meticulous
Berm Worm
Re: alloy hub skyway removal
June 12, 2010, 06:57 AM »
te rivets cannot be replicated, you wil have to build them with bolts....
R.I.P O.M. Far short of the finish line...
kirk
Without a Freewheel romoving tool you have to disassemble the Freewheel by unscreing the end plate, removing the cog plus bearings, springs etc and then with a pair of Stilsons get the remaining treaded band off.
The only way to get the Hub off is to drill the rivet heads off and rebuild using the correct size bolts and nylock nuts.
I spent many a day converting fronts to rears in the late nineties as a shop in Nottingham had about 50 NOS Black front tuffs from the old Raleigh factory but no rears.
Faze7-Ade
Curb Endo
June 12, 2010, 07:27 AM »
Had a similar problem myself.
Went to the local bike shop to buy a freewheel removal tool but they didn't have one to fit. They said as long as I didn't need the freewheel (it was knackered anyway and I wanted to replace it) to stick it in a vice, and unscrew it that way.
So I carefully put the thing in a vice, slowly increasing the pressure just enough to stop the freewheel turning but not so much that it crushed the hub and hey presto I got the freewheel off no probs.
Might be easier than replacing a hub ?
pickle
Site Supporter
My life is Radbmx
Posts: I am a geek!!
June 12, 2010, 07:30 AM »
I've taken off many a freewheel with the old big screw driver and mallett. Just be careful not to slip and impale your leg
MULL
June 16, 2010, 11:04 PM »
Agree with screwdriver & mallet....proper old school!
meticulous
Berm Worm
June 17, 2010, 07:04 AM »
better use a chisel and lump hammer, works everytime for me...
