975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 08:51 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Can you dye a re-pop Kashimax
Author Topic: Can you dye a re-pop Kashimax  (Read 832 times)
Rodgy1970
« on: June 09, 2010, 09:50 PM »
I think you can OK but want to doublecheck, cheers   :daumenhoch:
Rodgy1970
Re: Can you dye a re-pop Kashimax
« Reply #1 on: June 09, 2010, 10:11 PM »
if its nylon yes, check underneath it.  I expect so
it does say nylon on the underneath
cheers
glen
Rodgy1970
« Reply #2 on: June 09, 2010, 11:08 PM »
yes then it will work!
cheers
russ j
« Reply #3 on: June 18, 2010, 08:26 PM »
Yes the re-issue Kashimax seats can be dyed no problem:
I've dyed my White one i had on my AP and the results are spot on:
Before:
After:
I used a very large metal bucket,half filled it with water (enough to make sure the seat was fully submerged) plenty of table salt and 1 small tub of the black Dylon.Then i put the bucket onto the oven hob and let it go on the boil for around 2 1/2hrs.The results are well worth it.
The rails don't get ruined,all i would say is if you are gonna put an 'AERO' decal on it make sure you put it on AFTER you've dyed the seat as the one i have on mine i put on before i dyed it and the dye 'slightly tinted' the AERO decal but the KASHIMAX gold stamp was not damaged in the slightest...
Ps....if you do dye one of these remember to take off the rear decal as this will get ruined if left on
Russ.... :daumenhoch:
« Last Edit: June 18, 2010, 08:28 PM by russ j »
