975792 Posts in 138942 Topics by 6363 Members - Latest Member: Bmxflex November 12, 2024, 09:59 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Ody Driver fitting
Author Topic: Ody Driver fitting  (Read 654 times)
Stella Dave
Ody Driver fitting
« on: June 02, 2010, 08:58 PM »
Took my Ody 10t driver off to remove the grease I'd put in as it was sticking a wee bit.
When putting it back in and the nut on hand tight the driver is very stiff! As soon as it tightens it goes against the rubber seals and gets stiff.
Cant see any other way to put it in but I dont rem it being that stiff before.
Any fitting guides please??
Offline Gary72
Re: Ody Driver fitting
« Reply #1 on: June 02, 2010, 09:47 PM »
Is there a collar that you have left out?
Goes between the bearings in the hub and the bearings in the driver.
Bettyswallocks
« Reply #2 on: June 02, 2010, 10:00 PM »
What hub is it dude?
Odyssey have some instructions online
http://www.odysseybmx.com/techcorner/
Stella Dave
« Reply #3 on: June 02, 2010, 10:38 PM »
It's a 1 piece for use with Hazard Cassette.
The axle has a step in it so it only goes in so far. I think I have to get the distance just right with the seal using the opposite axle nut??
