975755
TattooedYorkie
September 23, 2024, 08:29 PM
unknown frame
Topic: unknown frame (Read 4706 times)
goosegp
unknown frame
May 23, 2010, 08:26 PM »
hi there
just picked up this frame and forks been stood in garage for a long time, any one have any ideas what it might be.
forks appear to have a load of rake (dont look bent by accident) frame and forks both aero tube
only making is frame number stamped on right rear drop out G344XXXX
cheers for any ideas
mattfx81
Cherry Picker
Re: unknown frame
May 23, 2010, 08:31 PM »
Peugeot?
Matt
goosegp
Re: unknown frame
May 24, 2010, 06:36 PM »
cheers for the idea.
scanning the net found a couple of pugs that do look similar but nothing exact.
mentioned it to the guy who gave me the frame and the only memory he has is of a possible reynolds sticker on the seat tube. i believe peugeot used reynolds tubes in the 80s so could be a good shout.
cheers
Rodgy1970
Re: unknown frame
May 24, 2010, 06:48 PM »
i thinks it's possibly an acorn freeway
mattfx81
Cherry Picker
Re: unknown frame
May 24, 2010, 08:42 PM »
I had a couple of pugs with reynolds tubing, aero down and cross bar and aero blade forks but the brake mounting wasnt the same as the one in the picture.
Matt
mattfx81
Cherry Picker
Re: unknown frame
May 24, 2010, 08:55 PM »
Yep looks like an acorn freeway the forks arent original on your frame if it is an acorn. BMX bi weekly, volume 4-issue 20, page 30.
Matt
Last Edit: May 24, 2010, 09:03 PM by mattfx81
goosegp
Re: unknown frame
May 24, 2010, 09:15 PM »
cheers matt
do you know where i can find a picture of an acorn? googled bmx bi weekly and acon freeway with no luck.
do you know if this a frame worth building.
thanks again for the help
Paul
mattfx81
Cherry Picker
Re: unknown frame
May 24, 2010, 09:35 PM »
I will try and scan the page tommorow.
Matt
fischflo
900 Air
Re: unknown frame
May 24, 2010, 09:55 PM »
the forks look like the ones on greentoads Magnum in the musem -- with the forks now leaning
inwards
mattfx81
Cherry Picker
Re: unknown frame
May 25, 2010, 12:25 AM »
Matt
ronster
Re: unknown frame
May 25, 2010, 12:16 PM »
You maybe getting somewhere with your search then Paul?
jT Racing
BMX Overlord
i like bikes. :/
Re: unknown frame
Reply #11 on:
May 25, 2010, 12:33 PM »
looks a lot like a chro-mo akisu
ding dong
goosegp
Re: unknown frame
Reply #12 on:
May 25, 2010, 04:52 PM »
guys, cheers for the help.
Matt special thanks for scanning the photo.
it does look very much like the acorn freeway with an odd set of forks. the only akisu i can find appears to have a lower bridge on the rear forks fitted so i am heading down the acorn path.
bet there is zero chance of finding decals for an acorn freeway?
Ron, you were right these guys are good!
jT Racing
BMX Overlord
i like bikes. :/
Re: unknown frame
Reply #13 on:
May 25, 2010, 10:43 PM »
Last Edit: May 25, 2010, 10:49 PM by J.T.Racing
ding dong
goosegp
Re: unknown frame
Reply #14 on:
May 26, 2010, 05:56 AM »
life is never simple, just when you think you have all the answer.
JT,must admit that akisu looks close and the forks look to have the same profile and drop outs, cant see if they have the same rake from the picture.
think i will investigate akisu it bit more
jT Racing
BMX Overlord
i like bikes. :/
Re: unknown frame
Reply #15 on:
May 26, 2010, 09:30 AM »
the thing with akisu is, they were more of a manufacturer than a retailer/brand. many different brands of bmx used the standard stock made by akisu and some brands had there stuff made to their spec by the akisu factory. When i see that acorn saying made in england, i think maybe the decals were
because it's way too similar to be different. They are good quality chro-mo frames, the tig welded stuff anyway. When it's mig welded(big bubble gum welds) they are hi-ten steel instead of 4130.
ding dong
goosegp
Re: unknown frame
Reply #16 on:
May 26, 2010, 08:50 PM »
it does have very neat tig welding and i would say better than that on my burner and goose
maybe never know exactly what it is, have built it up to ride around with odd bits
probably a bargan for £30 as it came with the mint old skyways now fitted to the gp
unknown frame
