975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 12:41 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Brake Cable Question.
Author Topic: Brake Cable Question.  (Read 1031 times)
stu70
« on: May 22, 2010, 10:56 AM »
Are there any modern brake cables out there that would work with a Tech 3 lever and MX 1000 set up, I've been looking for a rear Dia Compe cable in black or red for ages, none ever seem to come up, or that aren't part of a complete front and rear set, so was just wondering if there was something else I could use.
Re: Brake Cable Question.
« Reply #1 on: May 22, 2010, 11:11 AM »
Odyssey Slic cables are pretty good but you will need to get a brake ferule from your LBS (locak bike shop), preferably an alloy one  :daumenhoch:
« Reply #3 on: May 24, 2010, 02:40 PM »
are they real?  i don't remember any of my DC cables having the ferrals at the ends like that??
« Reply #4 on: May 24, 2010, 02:54 PM »
Is it to ride or for a show build ? Have you not thought about just replacing the outer sleeve with some red / black stuff as required ?
There's all sorts on the bay - quick search found these in various colours :
http://cgi.ebay.co.uk/1x-Cycle-Brake-Gear-outer-cable-Bike-7-colours-/150411620161?cmd=ViewItem&pt=LH_DefaultDomain_3&var=&hash=item68c63ffc6d
« Reply #5 on: May 24, 2010, 03:05 PM »
what about this ::)
http://cgi.ebay.co.uk/Dia-Compe-Low-Friction-Cycle-Bike-Brake-Cable-REAR-/110523953809?cmd=ViewItem&pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item19bbbdb291
They are mountain bike brake cables, the lack of a ferule is the giveaway, that one only has a capped end  ;)
« Reply #6 on: May 24, 2010, 03:28 PM »
Yeah I thought they didn't look quite right  :daumenhoch:
stu70
« Reply #7 on: May 25, 2010, 11:06 AM »
Thanks for the help, much appreciated   :)
