975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 08:37 AM
RADBMX.CO.UK  |  Mid School BMX (>87) 1989 to 2003 (<05)  |  Mid School ( Keep the faith )  |  Do new skool bits go on mid skool frames?
Author Topic: Do new skool bits go on mid skool frames?  (Read 2078 times)
losidan
« on: May 19, 2010, 07:22 PM »
silly question i suppose but thought i'd check. Got an 92ish mongoose hooligan to clean and build, mainly for my little niece to use when she comes to ours. I have plenty of the original bits but wanted to get down with the kids and throw some new skool stuff on it too...mainly cranks...
So, do I need a specific size for the mid skool stuff.
Re: Do new skool bits go on mid skool frames?
« Reply #1 on: May 19, 2010, 07:35 PM »
you can run most parts just be carefull going very low on the gearing as you might have chain hitting the chainstay.
Barrera006
« Reply #2 on: May 19, 2010, 08:02 PM »
Spindles are generally 14mm not 10mm, may not fit the dropouts.
losidan
« Reply #3 on: May 20, 2010, 10:58 AM »
cheers...it is 1" threaded and I think I am ok on the headset stem front as already got em...
time to break out the coke and foil me thinks
Offline Jon The Bassist
« Reply #4 on: May 20, 2010, 11:11 AM »
True. Some 14mm slotted axles will fit though. Things like seat tube diameter vary between eras and makers.
« Reply #5 on: May 20, 2010, 11:35 AM »
or if you don't want to go cassette on the rear, Cyclesport (BMX City) do 10mm sealed hubs  :daumenhoch:
