975755
TattooedYorkie
September 21, 2024, 09:02 PM
Hub help
Topic: Hub help (Read 479 times)
Gary72
Site Supporter
BMX Nerd
Hub help
May 14, 2010, 08:23 PM »
I've just stripped a free agent rear cassette hub. It's loose ball on the drive side and has a sealed bearing on the other side. Only problem is the axle is like a pr1ck in a bucket in the sealed bearing. It was all quite tight when I stripped it. So I just undid everything. It has cone nuts on both sides. But I cant see how it will work when I put it back together. Anyone have a similar set-up?
I think that on the sealed bearing side it should have a top hat washer to stop the axle floating around.
Gary
HEYWOOD BMX
Re: Hub help
May 14, 2010, 08:52 PM »
Sounds just like the older Redline cassette hubs which did have a tophat washer.The washers were crappy alloy and were prone to exploding now & then! All was well until you noticed your rear wheel was feeling odd and making strange noises
Gary72
Site Supporter
BMX Nerd
Re: Hub help
May 14, 2010, 09:38 PM »
I looked up the bearing number and it says it's a 10mm bore, But the axle is sloppy, Will try my LBS and his box of bits.
Hub help
