975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 08:24 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Extending Handlebars
Author Topic: Extending Handlebars  (Read 1373 times)
nic968
« on: May 13, 2010, 04:19 PM »
 I'm looking at getting some bars extended before I get them refinished (they've been cut down a couple of inches each side)...
 Has anyone done this, or recommend somewhere/someone to do it?  ;)
Weeksy
Re: Extending Handlebars
« Reply #1 on: May 13, 2010, 04:28 PM »
SAWZALL
« Reply #2 on: May 13, 2010, 04:38 PM »
or animal
or you could even follow harris's trend for wide bars lol.
« Last Edit: May 13, 2010, 04:42 PM by dordymush »
nic968
« Reply #3 on: May 13, 2010, 05:32 PM »
 Cheers fellas.. :daumenhoch:
spesh
« Reply #4 on: May 13, 2010, 07:42 PM »
the simple way to do and ive done it is to buy some renthal motorcycle bar ends which bolt into the ends of the bars and have an external diameter of 22.2 mm which is the same size as the bars and then slide you grips over the top
ive ridden with these and they never move and the bars are now 2-3" wider :daumenhoch:
http://www.demon-tweeks.co.uk/images/product/summary/ren_bar-plug-ti.jpg
« Reply #5 on: May 14, 2010, 07:25 PM »
are they riders or just for show?
nic968
« Reply #6 on: May 15, 2010, 08:45 PM »
 They will be ridden, but probably not raced/thrashed....
Offline sawzall
« Reply #7 on: May 15, 2010, 09:06 PM »
here's how i do them for a show pony  but would be fine on a rider:daumenhoch:
« Last Edit: May 15, 2010, 09:23 PM by sawzall »
Offline poolysheriff
« Reply #8 on: May 15, 2010, 09:20 PM »
Yes but your clever Phil  :4_17_5:
scott250
« Reply #9 on: May 16, 2010, 12:44 PM »
I ride with some bars that have been extended, not as nicely welded as the pair in the reply above, but I've been riding these for a year - been fine so far.
I trimed them down to about 1" wider than they were originally (s&m slam bars, by the way) got them second hand from a friend - he had cut em about 1" ither side.
I cannot see them snapping off easily, if ever.
