975806
V6 DOW
November 24, 2024, 07:23 AM
PK Ripper, dropout savers and chain tuggage. Best solution!!
Topic: PK Ripper, dropout savers and chain tuggage. Best solution!! (Read 6662 times)
moley
May 10, 2010, 10:21 PM »
I'm gonna eventually build my PK XL up and it would need dropout savers to pad out the axle and protect the dropouts.
I would like to use chaintugs for added safety as it will be used on the track at some point.
I have a pair of the top hat washers for the rear axle and I have seen the full dropout slider insert jobbies.
I could possibly use one of the old metal chaintugs as a washer from the inside of the dropout but they are fugly.
I'd prefer a more elegant solution that would fit from the outside.
Any suggestions?
oldtired
540 Air
Dirty Old Man
Re: PK Ripper, dropout savers and chain tuggage. Best solution!!
May 11, 2010, 01:05 AM »
i use two methods 1....14 mm tugs with an insert on the axle ,14 to 10mm, just slightly thinner than the width of the tug, primo used to do nice lollypop tug ,the washer bit is about 40mm accross great for alloy frames, nice wide stopper to 8mm nyloc nut ,, method 2 this ones on my current rider a wheel with 14mm axel , ive slotted the axel down to 10mm or os size is it 3/8ths? so that the it fits in the dropout the hardware on a 14mm axel is big enough to stop a dinting on the ally on the inside, and the axel is strong enough to stand loseing 2mm of each side,, then used the primo tug on the outside , tightens up like a nuns..... often thought about makin bigger tugs for ally frames ,,, anyone got a lathe i can borrow?
meticulous
Berm Worm
May 11, 2010, 06:48 AM »
i have them big sliding washer thingys on my 99 ally quad and as long as you tighten the the wheel nuts tight enough you wont need the chain tugs....
R.I.P O.M. Far short of the finish line...
pickle
Site Supporter
My life is Radbmx
Posts: I am a geek!!
May 11, 2010, 07:14 AM »
get the Helix drop out savers and they'll do the job perfectly, as Sam says, do them up tight enough (but not over tight) and bobs your uncle
Peter J
BMX Nerd
I have issues
May 11, 2010, 07:54 AM »
Ian
I got these for mine
http://www.crupibmx.com/chain-tensioners-bomb.html
I might actually build a bike this year instead of just hoarding parts
moley
May 11, 2010, 09:56 AM »
The Helix website says they only fit looptails.
I have a 90's OS legal PK Ripper XL.
double chevron
540 Air
May 11, 2010, 10:15 AM »
Might be worth checking if they didn't have two sizes available ?
Anyhow I have some on a late eighties PK (so same dropouts than yours Iain) they fit like on Sam's retro quad
moley
May 11, 2010, 10:34 AM »
There are two sizes but I'll have to check my dropouts to make sure they fit!!
sam hudson
July 15, 2010, 04:21 PM »
Can you buy Helix dropouts in the UK or do you have to get them from the USA?? Got my Quad coming in a few days time and it can take aaaagggggessss to get stuff posted from over the pond?
Bigplinky
Cherry Picker
July 15, 2010, 05:20 PM »
I filed off the stupid retainer bumps at the end of the dropout slots so I could slide the top hat washers inside the dropouts and use a Profile Chaintug on the outside.
sam hudson
July 15, 2010, 08:38 PM »
Thats another question...what happened to top hat washers?? I can't find them anywhere ? I got a set for my 2005 Ripper but I can't find a set on ebay or anywhere else...any ideas?
Filed your frame
blimey!
sam hudson
Reply #11 on:
July 15, 2010, 08:53 PM »
Just answered my own question...doh
Got a set of front and rear top hats from Vert-ego.
