975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 05:58 PM
RADBMX.CO.UK  |  Mid School BMX (>87) 1989 to 2003 (<05)  |  Mid School ( Keep the faith )  |  mid school hub axles
Author Topic: mid school hub axles  (Read 1063 times)
calmac
« on: April 27, 2010, 09:46 PM »
I'm in the process of rebuilding a @98 haro zippo as a master copy and am having a problem on wheel axle sizes.
current wheels appear to be about 12mm or 1/2" wheel axles & obviously dropouts are same size.
most wheels i see are 3/8" or 10mm & i cant seem to find any axle convertors .
any ideas anyone please.
thanks
calum
andy_116
Re: mid school hub axles
« Reply #1 on: April 27, 2010, 09:49 PM »
yeah haro went through a weird stage of doing 12mm stuff, dunno if you will be able to get any converters but should work fine in a 14mm slot
calmac
« Reply #2 on: April 27, 2010, 09:52 PM »
sorry, i'm going the other way ie. 10mm wheels in a 12mm dropout.
just seem a bit too much play
calum
« Last Edit: April 27, 2010, 10:24 PM by calmac »
scott250
« Reply #3 on: April 27, 2010, 10:48 PM »
You could try to get those washers with the little sleeves on?
andy_116
« Reply #4 on: April 28, 2010, 12:00 AM »
calum
oh right, well you might be able to get you hands on some 10mm tubing and chop it up, if not ive run 10mm in 14 slots before and not had a problem (not ideal tho)
« Reply #5 on: April 28, 2010, 07:26 AM »
yeah as stated, Haro used 12mm drop outs on their forks......send SE-Bmxer a PM as he might have some 12mm washers for the forks  :daumenhoch:
failing that, you can get the 14mm alloy top hat washers and rub them down with a file  :daumenhoch:
calmac
« Reply #6 on: April 28, 2010, 01:15 PM »
Cheers, have dropped SE-Bmxer a pm.
calum
