975755 Posts in 138933 Topics by 6360 Members - Latest Member: TattooedYorkie September 23, 2024, 04:19 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Pro class holes
Author Topic: Pro class holes  (Read 2799 times)
Offline Munnyella
Pro class holes
« on: April 15, 2010, 07:58 AM »
Can any one tell me the size of the holes in pro class rims? (or where I can get them from? :LolLolLolLol:)
I fancy doing a set of 48 hole proclass rims for my street rider, might have to do the holes smaller than 36ers though.
Mark
wirewheel
Re: Pro class holes
« Reply #1 on: April 15, 2010, 08:04 AM »
i wouldnt advise drilling 48s man esp if they are double wall rims mongoose pro class were just single wall arayas drilled i just restored a set i wouldnt like to try and drill a set of rims unles i had serious engineering facilities and you definitely dont want to drill the holes the same size as 36h pc rims on 48s they will just fall apart my advice is find something else to tinker with.
Re: Pro class holes
« Reply #2 on: April 15, 2010, 10:10 AM »
Didn't Fly Bikes and Proper do a pro-class style new school wheel?
Offline Peter J
  • I have issues
Re: Pro class holes
« Reply #3 on: April 15, 2010, 10:28 AM »
Hole size should not make a big difference, 48 spokes will have better liner stress displacement that 36 and with the rim having a double wall it will help (a bit).....that said, it depends what the rims intended use is for.......and the overall mass placed on the rim......e.g are you a 6’ 2” chunky monkey !!!  :crazy2:
I’ve done a set of 36's myself, although I used a £63,000 CNC miller.........handy if you've got one !!!!  :2funny:
But It’s very easy to do a set manually..(you will need to de-spoke the rim)..will just take a while as to do it correct you’d have to “drill” each hole three times..... :shocked:
I would go with a smaller hole simply because you have a smaller gap between the spokes and aesthetically it would look better.  :daumenhoch:
Offline Peter J
  • I have issues
Re: Pro class holes
« Reply #4 on: April 15, 2010, 10:40 AM »
That looks a nice sized hole.... :daumenhoch:
And you cannot beat a nice sized hole  >:D
ozone
Re: Pro class holes
« Reply #5 on: April 15, 2010, 10:57 AM »
Rim driller. :-* :-* :-*
The Styler
Re: Pro class holes
« Reply #6 on: April 15, 2010, 11:01 AM »
i use a cone-cutter, done afew sets and you only have to drill once  ;)
The Styler
Re: Pro class holes
« Reply #7 on: April 15, 2010, 11:27 AM »
« Last Edit: April 15, 2010, 12:26 PM by The Styler »
Offline Peter J
  • I have issues
Re: Pro class holes
« Reply #8 on: April 15, 2010, 11:39 AM »
Good results  :4_17_5:
I was thinking:
Pilot Hole
Drill Hole
Ream Hole......Hummm nothing like reaming a hole  >:D
Offline jT Racing
  • i like bikes. :/
Re: Pro class holes
« Reply #9 on: April 15, 2010, 12:18 PM »
what's the proper size on proper pro class? and what are the hole centers, centre to centre?
ding dong
wirewheel
Re: Pro class holes
« Reply #10 on: April 15, 2010, 05:13 PM »
i wasnt thinking anything to do with the strength just that it wud be a bastard to drill 94 holes in rims without a jig. good luck tho my og pro class rims a looking real nice with green foils
Offline Munnyella
Re: Pro class holes
« Reply #11 on: April 15, 2010, 07:17 PM »
I have a pillar drill, the rims are already de spoked and i'm gonna make a jig so each hole is exactly as wrong as the other.
Step drill is a good idea, might give that a whirl, I reckon on a finshed hole size of 7mm will be OK.
They are single wall arayas if that makes a diiference.
Mark M
Re: Pro class holes
« Reply #12 on: April 15, 2010, 11:11 PM »
Joff (NORTY40) measured them at 10.77mm on a digital caliper  :daumenhoch:
Re: Pro class holes
« Reply #13 on: April 16, 2010, 12:25 AM »
The less said about that the better   :yahoo_silent:
Not one of my better jobs  :LolLolLolLol:  ( John , bobafett was rolling around in my garage pi55ing his sides when he saw my attempt !! )
Hope you have more luck with it than I did Mark  :daumenhoch:
