975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 01:36 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  spraying tips
Author Topic: spraying tips  (Read 1005 times)
spraying tips
« on: April 10, 2010, 10:19 PM »
im restoring a set of cranks and want some spraying tips, ive put 3/4 coats of primer on them and left to dry for 24 hours, they could do with another couple of coats, do i flat them now or after ive put the extra coats on and then again before the finishing coats of gloss, nice1 gaz :daumenhoch:
Re: spraying tips
« Reply #1 on: April 10, 2010, 10:21 PM »
Gaz
I would flat them now that they are dry and then again after the extra coats.  Also flat between the coats of finishing coats and clearcoat.
Re: spraying tips
« Reply #2 on: April 10, 2010, 10:22 PM »
nice1 stidds :daumenhoch:
HEYWOOD BMX
Re: spraying tips
« Reply #3 on: April 10, 2010, 10:29 PM »
 :) And don`t rush `em to get them finished.Made this mistake with a set of forks last week and had to strip/start again.. :daumenhoch:
 Strip the forks that is,not get naked!
Tim38
Re: spraying tips
« Reply #4 on: April 10, 2010, 10:36 PM »
been on the cans myself for the 1st time this wknd some haro bars of the cheap mirra i got have had a repaint,sanded them down to raw bit of primer let it dry then gave it a light rub down, and a have put on a few coats of black they are looking much better,gave them a light spraying of primer,and used halfords black satin paint,ive got the bug for this now.
Re: spraying tips
« Reply #5 on: April 10, 2010, 10:38 PM »
spraying naked sounds good to me, im having some of that :crazy2:
Re: spraying tips
« Reply #6 on: April 10, 2010, 10:43 PM »
This technique saves any clothing from overspray & feels good on a day like it was today  :daumenhoch:
Don't do any oven pride work like this though !  :LolLolLolLol:
Offline superbikedan
Re: spraying tips
« Reply #7 on: April 10, 2010, 10:45 PM »
it's all in the prep for the final finish, on tubular work i just flood it with primer,
a couple of good wet coats and you've built up enough thicknes to flat the hell
out of it till it's smooth as silk then a couple of top coats and it should look as
smooth and sweet :daumenhoch:
ps.. dont worry about runs in the primer, look at it as thicker paint and it will fill
any marks once you've flatted it out  ;)
« Last Edit: April 10, 2010, 10:46 PM by SuperBikeDan »
Tim38
Re: spraying tips
« Reply #8 on: April 11, 2010, 03:10 PM »
dan whats the best way for getting paint off,spent a good hour with wet and dry getting the bars to raw,is there an easier way.
Offline Rombloke
  • do one
Re: spraying tips
« Reply #9 on: April 11, 2010, 05:13 PM »
wire brush and dettol
haro, how do you do
