975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 01:18 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  dmr cranks
Author Topic: dmr cranks  (Read 1477 times)
Offline stuntmaster
dmr cranks
« on: April 08, 2010, 07:21 AM »
how do i get the bearing off to get chainwheel off as the arm you see does not have bolt ie like two peice cranks .
anyone had a set of these
no1stuntmaster on instagram
snav69
Re: dmr cranks
« Reply #1 on: April 08, 2010, 08:01 AM »
Put it back in the frame and whack the spindle from the other side  :daumenhoch:
 :coolsmiley:
Re: dmr cranks
« Reply #2 on: April 08, 2010, 02:50 PM »
 :coolsmiley:
WHS^^^ +1
Offline stuntmaster
Re: dmr cranks
« Reply #3 on: April 08, 2010, 02:55 PM »
can`t do that as don`t have a frame with that size bb . i can see what you mean tho .
Re: dmr cranks
« Reply #4 on: April 08, 2010, 04:36 PM »
Rest the chain ring on a vice (covered with card) with the vice open enough for the crank arm only to fit through and whack the spindle end with a rubber mallet, the chainring and the bearings should come off together
Offline stuntmaster
Re: dmr cranks
« Reply #5 on: April 08, 2010, 08:54 PM »
right i got arm in vice and bloody bearing fell apart and left the inner bush of the bearing still stuck on , typical i have another go later after soaking bush in oil . wish i never bought the bloody things now
Offline kuwahero
    • Western Titans
Re: dmr cranks
« Reply #6 on: April 08, 2010, 09:15 PM »
Offline stuntmaster
Re: dmr cranks
« Reply #7 on: April 09, 2010, 06:14 PM »
cheers for info but i think that was the reason i got them cheap ie bearing press stuck on i get them fixed but now just chuck them in garage for another day
