975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 10:01 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  little spockets, talk to me
Author Topic: little spockets, talk to me  (Read 619 times)
nomad
« on: April 04, 2010, 03:39 PM »
After riding in a park for the first time in 12 years last night I wanna make some changes to my bike. First being a new rear wheel and a little sprocket. So, whats gonna work for me? I wanna use my profiles still, and need a 14mm rear axle. What size sprocket and rear do I need? And is it even possible with the profiles?
Offline kev-s
Re: little spockets, talk to me
« Reply #1 on: April 04, 2010, 03:43 PM »
u need 25 tooth sprocket and a 9 tooth rear cassette to match the usual 44-16 setup of the 90's
try to avoid 23t sprockets and 8 tooth cassettes as these tend to snap chains
they will work fine with ur profiles
« Reply #2 on: April 04, 2010, 03:47 PM »
speak to stodge at the radshop he will sort you out
« Reply #3 on: April 04, 2010, 04:00 PM »
Before you dive in, what frame u got? make sure you account for your brake lugs if they are on the chainstays , I.e will the chain clear the brake if you run small sprockets (if you run brake that is) :daumenhoch:
scott250
« Reply #4 on: April 04, 2010, 09:33 PM »
Kev s knows the deal - i use 25 - 9 too, its spot on.  You need brakes up on the seat stays so your chain don't cut through them - You might also need a spacer with a smaller sprocket as the chain might catch on the cranks - not sure if this is a problem on profile cranks, but it was for me with primo crank using a profile sprocket.
« Reply #5 on: April 04, 2010, 09:38 PM »
I think he's riding a standard with chainstay lugs
nomad
« Reply #6 on: April 04, 2010, 09:45 PM »
I am indeed, talking to Twobobrob last night and he suggested I might get away with a lower profile brake thou? bit of a bugger, dont wanna get all the bits and have it not work.
lodge
« Reply #7 on: April 04, 2010, 10:47 PM »
28/10 might be better with a chainstay brake.
« Reply #8 on: April 05, 2010, 02:01 PM »
lowest i could go with mine was 36/13 without the chain catching the brake.
nomad
« Reply #9 on: April 05, 2010, 02:50 PM »
what frame was that on, may well do the trick tbh
« Reply #10 on: April 05, 2010, 05:43 PM »
s & m challenger mucka.
here you can see it just misses.
i bought an odyssey evolver brake and that was to thick on the arms so had to stick with the tecto or whatever it was.
« Reply #11 on: April 07, 2010, 08:36 AM »
Nomad........if you want a 28t sprocket i have a colony one you can have mate.......even has the top hat washer as well  :daumenhoch:
it's plain old bare alloy so should go with any colour scheme
PM me your addy and i can send it off mate  :daumenhoch:
