975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 30, 2024, 07:30 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  A Naked Little Brit
Author Topic: A Naked Little Brit  (Read 2724 times)
Offline Bigplinky
A Naked Little Brit
« on: March 27, 2010, 05:19 PM »
1984 Lea Cycles Curtis Atom Mini Frame, forks and Bars. JJ just got the crappy chrome stripped off this for me and I'm totaly blown away by the craftsmanship underneath, just thought I'd share  ;D
monkian
Re: A Naked Little Brit
« Reply #1 on: March 27, 2010, 05:30 PM »
Sexy little thing ;)
Don't let K9 too near or he'll try and mount it :D
« Reply #2 on: March 27, 2010, 05:45 PM »
true english craftmanship  :4_17_5:
daz bmx it!
« Reply #3 on: March 27, 2010, 05:54 PM »
 :4_17_5: :smitten:
Offline Peter J
  • I have issues
« Reply #4 on: March 27, 2010, 06:03 PM »
Thats some nice workmanship there....... :4_17_5:
If only we could still knock stuff out like that at the right price  :'(
 :Great_Britain:
trasher
« Reply #5 on: March 27, 2010, 06:04 PM »
 :coolsmiley: :4_17_5:  bloody marvelouse
Offline Bigplinky
« Reply #6 on: March 27, 2010, 06:27 PM »
Bloody good eyes  :LolLolLolLol:
The funny thing is going Brit used to be the cheap option BITD
Offline stevochb
« Reply #7 on: March 27, 2010, 07:04 PM »
Work of art that welding :smitten:
moanjam
« Reply #8 on: March 27, 2010, 07:07 PM »
lush that andy , what you got planned for her ??
« Reply #9 on: March 27, 2010, 07:08 PM »
X2
Be nice to polish it up and just clear coat it  8) :LolLolLolLol:
moanjam
« Reply #10 on: March 27, 2010, 07:11 PM »
X2
is that after welding a couple o nice gusset plates in there johnny  :D
« Reply #11 on: March 27, 2010, 07:15 PM »
Mmmmmmm gussets  :smitten:
 :D
But seriously - I do like the curtis frames - very nice  :coolsmiley:
Offline Bigplinky
« Reply #12 on: March 27, 2010, 07:17 PM »
I wish the tubing was good enough to leave it naked but the arse end is a bit too pot marked to leave bare. So it'll be off to SBD soon for a coat of yellow and got mostly red bits to go on it (was gonna do it for the little'un but got him a new school mini instead). Gotta see Del for some decals as well  ;D
Toying with the idea of doing my new school Curtis jump frame in naked  :daumenhoch:
« Last Edit: March 27, 2010, 07:19 PM by Bigplinky »
bobbysam
« Reply #13 on: March 27, 2010, 07:31 PM »
Those welds are fantastic, almost a shame to cover them up  :daumenhoch:
trasher
« Reply #14 on: March 27, 2010, 08:31 PM »
huhmmmm  there not welds ,,,there brazed  :coolsmiley:   :LolLolLolLol:
« Reply #15 on: March 27, 2010, 08:37 PM »
Actually Glen, when bronze or brass is used as the jointing compound it's called "Braze Welding"  :P
Offline Peter J
  • I have issues
« Reply #16 on: March 27, 2010, 08:45 PM »
 :coolsmiley:
Smart arse....but he's right
In another similar usage, brazing is the use of a bronze or brass filler rod coated with flux together with an oxyacetylene torch to join pieces of steel. (For brazing small or thin pieces where the heat is lost slowly, a "swirljet" propane torch with propane or hotter burning MPS gas can be sufficient.) The Welding Society prefers to use the term braze welding for this process, as capillary attraction is not involved, unlike the prior silver brazing example. Braze welding takes place at the melting temperature of the filler (e.g., 870 °C to 980 °C or 1600 °F to 1800 °F for bronze alloys) which is often considerably lower than the melting point of the base material (e.g., 1600 °C (2900 °F) for mild steel).
In Braze Welding or Fillet Brazing, a bead of filler material reinforces the joint. A braze-welded tee joint is shown here.Braze welding has many advantages over fusion welding. It allows you to join dissimilar metals, to minimize heat distortion, and to reduce extensive pre-heating. Another side effect of braze welding is the elimination of stored-up stresses that are often present in fusion welding. This is extremely important in the repair of large castings. The disadvantages are the loss of strength when subjected to high temperatures and the inability to withstand high stresses.
The equipment needed for braze welding is basically identical to the equipment used in brazing. Since braze welding usually requires more heat than brazing, an oxyacetylene or oxy-mapp torch is recommended.
‘Braze welding’ is also used to mean the joining of plated parts to another material. Carbide, cermet and ceramic tips are plated and then joined to steel to make tipped band saws. The plating acts as a braze alloy.
« Reply #17 on: March 27, 2010, 08:51 PM »
Smart arse....
You love me really Pete  :-*  :LolLolLolLol:
trasher
« Reply #18 on: March 27, 2010, 08:56 PM »
fookin anal cnut  :2funny:    i was just stating its brazed and not welded (welded as we know) fook it ill get my coat  :laugh:
« Reply #19 on: March 27, 2010, 09:06 PM »
I know you were mate - but I love fookin wit ya  :LolLolLolLol:
trasher
« Reply #20 on: March 27, 2010, 09:09 PM »
thats it ,,them winners choice are going on my rider and im going to pull the radest skids all day long on them  :LolLolLolLol:
then swap the front for the rear and do the same ,,,untill they start to buldge  >:D
Offline Dingobmxer
« Reply #21 on: March 27, 2010, 09:13 PM »
wow  :shocked:
work of art that
Dingo
« Reply #22 on: March 27, 2010, 09:15 PM »
You'll want a coaster brake for that Glen  :-*  :2funny:
Sorry for all this in your thread bigplinky - it's all Glen's fault  :yahoo_silent:
trasher
« Reply #23 on: March 27, 2010, 09:21 PM »
yep sorry for the hijack plinky  ;)   blame the fett  :coolsmiley:
Offline Bigplinky
« Reply #24 on: March 27, 2010, 11:46 PM »
Fookin hell Pete I know where to come if I've got a bit of an insomnia problem  :LolLolLolLol:
Actually got an 80's motorbike frame (Moto Martin) that is Bronze welded 4130, looks fookin ace  ;D
