975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 09:30 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  bottom bracket sizes ?
Author Topic: bottom bracket sizes ?  (Read 851 times)
calmac
« on: March 06, 2010, 05:01 PM »
Right i'm baffled........ordered a set of 3 piece cranks to upgrade from my 1 piece currently fitted to my Mid School Haro Zippo.
Was advised it came with US sized BB kit & axle to suit, axle is for a conversion because it is threaded internally like a 1 piece axle to allow tightning ( frame obviously non threaded & about 52mm internal size)
On inspecting BB kit, cups supplied almost perfectly sit inside existing frame cups being a lot smaller.
On doing a bit of research appears there's a Mid/US bearing type--does this sound like what i have ?
I am reasonably knowledgable in BMX (at least i thought i was), but this has me pullin' my hair out   :rant:
PLEASE HELP ME !!!!!!!!!!!!!!!!!!
Thanks Calum
calmac
Re: bottom bracket sizes ?
« Reply #1 on: March 06, 2010, 05:39 PM »
Thanks for replies guys, what i have isn't a sealed bearing conversion,it's exactly like the 1 piece set up ie. cup & bearing.
Like i say new cup & bearing is just like a smaller version of the original 1 piece ones & if you sit the new cup inside original cup it sits perfectly inside .
I was going to build up ,but frame off being painted just now.
I've now established it aint a Mid/US as it (looking at pic posted in previous) def. not like that, or a pop in type like the blue one in the previous reply.
thanks
calum
calmac
« Reply #2 on: March 06, 2010, 06:47 PM »
Sorry Glen, aint got a camera here.
tried fittings from 1 piece to see if i could just use them with new axle & cranks, but threads on new axle (look exactly same as 1 piece axle) are smaller sized too, so bang goes that option.
this is a link to what i should have but BB kit is deff. not the same
http://www.ukbikestore.co.uk/product/196/3302_175_02/khe-prism-3pctubular-cranks-wbb---black.html
i measured new cups at 45 mm not 52 as they should be & bearings are obviously smaller to suit.
calum
