975755
TattooedYorkie
September 23, 2024, 10:33 PM
fixing thread on alloy seatclamp with solder?
Topic: fixing thread on alloy seatclamp with solder? (Read 747 times)
firebird4130
March 05, 2010, 03:33 PM »
Is there any way to fix a threaded seatclamp using solder or something and then sticking the bollt in so it rethreads it/?
cheers
MartyC
Berm Worm
Re: fixing thread on alloy seatclamp with solder?
March 05, 2010, 03:43 PM »
You can get it filled with alloy weld and then re-drilled and re-tapped with a thread however, it may not go as tight as you need to hold the seat post in place
soll36
March 05, 2010, 03:48 PM »
you could do it with a heli-coil (thread repairer), otherwise the bolt will pull out as said above when ya tighten it.....
firebird4130
March 05, 2010, 04:24 PM »
hmmm, helicoil, sounds beyond me but I'll look into it
cheers
