975755
TattooedYorkie
September 25, 2024, 07:39 AM
Mid School ( Keep the faith )
mid school loose bearing hubs
Topic: mid school loose bearing hubs (Read 872 times)
smiler4130
February 28, 2010, 06:33 PM »
Just out of interest does anyone know if you can replace the steel cups that the bearings sit on inside the hub? ( the ones that crack when you been running your spindle to loose) If so is it an easy job and do i need any special tools apart from myself
to do so?
HEYWOOD BMX
Re: mid school loose bearing hubs
February 28, 2010, 06:42 PM »
Yep,most general bike shops,especially old family run ones should be able to help.
smiler4130
March 04, 2010, 04:46 PM »
Thanks Heywood for the info
. But i was looking more to do it myself i am guessing i could knock the old cups out with a screw driver and hammer? Then get the new cups pressed in. Does anyone know if you can buy these cups and if so where? thanks
