975808
Robertflamn
November 27, 2024, 12:34 AM
PAINTING IN THE LETTERS ON TUF NECK STEMS AND DC CALIPERS
Topic: PAINTING IN THE LETTERS ON TUF NECK STEMS AND DC CALIPERS (Read 769 times)
HARORIDER
Look Back
February 28, 2010, 11:31 AM »
ok problem is i wanna paint some calipers and a stem but then wanna paint in the "sunken" letters in a different colour what is the best way of doing this so it looks professional? someone said you can just paint it in and then just wipe the excess off but i can't see this happening without it then taking the first colour off round the edges
dordymush
Berm Worm
Re: PAINTING IN THE LETTERS ON TUF NECK STEMS AND DC CALIPERS
February 28, 2010, 11:55 AM »
i think you can get some new stickers for the calipers if they mx ones.
sure i seen em on ebay.
i know i aint got a steady enough hand to try and paint em in.
HARORIDER
Look Back
February 28, 2010, 11:56 AM »
no mate 880's and really wanna make them look original
Moose
540 Air
February 28, 2010, 05:09 PM »
If the main coat of paint is dry, it won't come off.
Paint over the letters with the second colour and wipe off, leave to dry
Rodgy1970
February 28, 2010, 05:51 PM »
go to an art shop and get a quality fine brush, wouldn't say itll make it easy but it'll help, you'd be surprised the difference it'll make, I saw a thread on the museum and the fella used model paint as it's designed to be applied by brush
GTnumber1
Look Back
February 28, 2010, 09:38 PM »
on the calipers its a peace of piss make sure the paints hardend and you can mask off the brake and lightly spray over the letters and once its dry you can use compound to get the excess off, but the tuf neck ull only/maybe be able to do it if you polish it up as the tigers head is not deep enough to prime paint and then try to paint the head over in a diffrent colour
Banachek BMX
March 05, 2010, 10:43 AM »
Yep - What Stephencosta said!! 880's work will that way. I had a white set powdered, then masked off the as much of the caliper as poss just exposing the logos, then used normal spray paint enamel (from B&Q - called Plasticoat). let that dry, take off the masking then used a very fine between coats finishing paper to remove the excess paint from around the logos. I was very pleased with the result - good luck with your resto
