975755
TattooedYorkie
September 25, 2024, 09:26 PM
Old School BMX 1980 - 1988
If you like my Torker, maybe you'll like this: 1979 Patterson Anderson Avalanche
Topic: If you like my Torker, maybe you'll like this: 1979 Patterson Anderson Avalanche (Read 1999 times)
PlanetX
February 24, 2010, 04:43 PM »
1979 (maybe 1980) Patterson Anderson Avalanche built like Richie Anderson's 1979 bike, but blue instead of red.
PlanetX
Re: If you like my Torker, maybe you'll like this: 1979 Patterson Anderson Avala
February 24, 2010, 04:44 PM »
Spec and more pics.
Frame: Anderson Avalanche, OG nickel, OG stickers
Fork: Redline Microline, NOS
Headset: Frankenstein Schwinn, Tange and Hatta parts
Stem: Tuf-Neck, Un-Stamped
Bars: Redline Microline V-Bar, OG finish
Seatpost: VDC fluted alloy
Saddle: Kashimax MX
Seatclamp: Suntour
Cranks: Campagnolo Strada 175 with Sugino, drilled, 51T chainring, Campagnolo chainring bolts, Campagnolo crank caps
BB: Torker sealed
Freewheel: Suntour, 3/32" 18-tooth
Pedals: Reedy
Chain: Regina Drilled
Wheels: Araya 7b front, Araya 20 x 1 1/8” rear, Suzue hubs
Tires: Mitsubishi Comp II 20 x 1.75 front, 20 x 1 1/8” Swallow rear
Brakes: Mafac center-pulls with Kool Stop Continental pads, Dia-Compe Quick Release cable hanger, Campagnolo cable clamps, Pre-Bent Dia-Compe with rubber sleeve
Grips: A’me Bubble Font Tri
Other: Vinyl frame and handle bar pads, Tuf-Neck stem pad, 44-16 Designs Handmade Replica number plate
Last Edit: February 24, 2010, 04:51 PM by PlanetX
OrgasmDonor
Berm Worm
I got the sauce for beef butterflies
Re: If you like my Torker, maybe you'll like this: 1979 Patterson Anderson Avalanche
February 24, 2010, 04:54 PM »
fookin lovely build dude
guessing the huge chainring was to compensate for the speed of the old downhill tracks, but what was the idea behind the diff size rims?
dan-dare
February 24, 2010, 05:02 PM »
yep, tis a beauty.
PlanetX
February 24, 2010, 05:09 PM »
You got me and Richie has no idea, either. He was only 12 at the time and his dad built his bikes. Apparently his dad was a bit of a tech wiennie and came up with the set-up. The 51T paired with a 19T rear (Richie ran a 19T, I have an 18T.) isn't so high really. A bit taller than 44-16. He also ran 180 cranks--and he was pretty small at the time.
Why the bigger rear wheel? No clue, but I do think that and the large chainring led the his using the one-off frame he had with the center-pull brakes mounted on the chainstays. If you run the center-pulls under the seatstays, as was popular at the time, the brakes rub on the chain. That said, running them as I am works fine, so not sure why he did that, either.
baldbmxer
February 24, 2010, 05:18 PM »
Really nice build. Quirky as hell but cool as hell at the same time
Love the nickel finish.
OrgasmDonor
Berm Worm
February 24, 2010, 05:21 PM »
didnt really notice the freewheel size til after i posted
but reckon i would have been logically correct
Jt
900 Air
February 24, 2010, 05:38 PM »
bad ass bike..
love it
markyp
900 Air
February 24, 2010, 06:33 PM »
wow rare bit of kit
Jon The Bassist
Flip-Whip
February 24, 2010, 06:58 PM »
51/19 equates to about 43/16, the slightly taller 1 3/8 rim makes it nearly the same as 44/16 on a 20x1.75 rim
kevin (A.K.A) kai riviere
February 26, 2010, 08:33 AM »
the bigger rear wheel may possibly have been to fine tune the gear ratio. i've seen it done here in the UK back in the 80's when you can't get the desired ratio with a 20" wheel. slower gates/acceleration but higher top end once rolling & the 180mm cranks may have been to compensate for the gate/acceleration issue.
dordymush
Berm Worm
Reply #11 on:
February 26, 2010, 12:37 PM »
lovin that.
my fav rider bitd
20to26
Site Supporter
Look Back
Reply #12 on:
February 26, 2010, 04:52 PM »
I love replica builds. Very cool and unique for sure
poolysheriff
Team Moderator
Flip-Whip
Reply #13 on:
February 26, 2010, 05:36 PM »
Nice work
bobafett
Team Mechanic
Tail Whip
mongoose addict
Reply #14 on:
February 26, 2010, 11:33 PM »
Some cool parts there for sure
The campy cranks and reedy peds are 2 that stand out for me
se
Reply #15 on:
February 28, 2010, 11:46 AM »
Absolute beaut nice work.
