975882 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 16, 2025, 08:36 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  scuff on kashi aero
Author Topic: scuff on kashi aero  (Read 1580 times)
moanjam
scuff on kashi aero
« on: February 13, 2010, 03:57 PM »
got this little scuff on the nose of my black kashi whats the best way of sorting it or making it less noticeable  :daumenhoch:
Re: scuff on kashi aero
« Reply #1 on: February 13, 2010, 04:02 PM »
big fookin hammmer and a red hot poker..hope this helps :D
« Reply #2 on: February 13, 2010, 04:03 PM »
scuff up the rest of it so that it all matches  :buck2:
moanjam
« Reply #4 on: February 13, 2010, 04:27 PM »
cheers lads  :crazy2:
Offline jT Racing
  • i like bikes. :/
« Reply #5 on: February 13, 2010, 05:44 PM »
a bit careful with a heat gun and it should at least darken off and then it's up to you if you try and mimic the surface with a bit of jiggery pokery :LolLolLolLol:
ding dong
moanjam
« Reply #6 on: February 13, 2010, 05:49 PM »
i think a bit heat could the way forward  :daumenhoch:
Bettyswallocks
« Reply #7 on: February 13, 2010, 05:55 PM »
Colour it in with black marker pen?
oldboyburner
« Reply #8 on: February 13, 2010, 09:18 PM »
a bit of fine texturised paint in a aerosol we use it at work to repair bumpers
« Reply #9 on: February 13, 2010, 09:24 PM »
i thought about that, a mate of mine used to do cosmetic interior repair on cars. fag burns etc. and he had a load of textured paints for plastics. might be worth a try? thats only a real small scuff mind you maybes be making it look worse? there is a lad on burnerworls that makes crappy looking seats look brand new you could ask him?
moanjam
« Reply #10 on: February 13, 2010, 09:28 PM »
it is only small, that pic makes it look massive, like you say maybe something drastic like paint might make it worse thats why i posted cos i'm a heavy handed fooker and usually go in all guns blazin and end up makin a balls up off things  :LolLolLolLol:
oldboyburner
« Reply #11 on: February 13, 2010, 09:39 PM »
well i spray bmw,s  ;) for a living
i had a kashi of another member it was red he had a go at sanding it it looked rough
when i got it so i gave it a coat of satin laquer with texature in and it looks brand new now
have a word with n2cus he will beable to help  ;)
neiljonarcus
« Reply #12 on: February 14, 2010, 08:09 AM »
yes dean bring it up i have textured acylic black in the ruhbard and custard shed  ....... diddle d dah diddle d dah d da d da daaaa     :LolLolLolLol:
« Reply #13 on: February 14, 2010, 08:37 AM »
Hi dean...
If you rub it down and then re-texture it with a spray the textured finish will be completely differant, and then you will have to re-coat all the seat with a satin colour aerosol, which then means you have a sprayed seat, which will make it worthless, leave it as it is,if you heat it up with a hot air gun you will and try melting it you will make it worse, take it from me, i've done thousands of car bumpers.... dont fook about with it or you will make it worse if you dont know what you are doing... best thing you could do is very lightly rub it down with fine wet n dry (maybe 800's) only over the scuffed bit to take the rough edge off then just try to colour it in with a marker or something as the plastic will lighten in colour when its rubbed down...
then leave it alone!!!!    :)
In fact just looking at it again, dont even rub it down, you will make it worse, i dont care how skilled you are!!!   just colour it in a bit with a marker.... ;)
gadd
« Reply #14 on: February 14, 2010, 10:48 PM »
try a tiny bit of wd40 on it to darken it down
moanjam
« Reply #15 on: February 17, 2010, 04:11 PM »
cheers for the advice lads , i went for a light rub down then i soaked it in that silicon dash polish spray and it worked well
« Reply #16 on: February 17, 2010, 04:14 PM »
 :shocked: blimey has come out well that hasnt it. impressed
tigerbrown
« Reply #17 on: February 17, 2010, 04:15 PM »
Looks good!!!
Bargain that like!!
moanjam
« Reply #18 on: February 17, 2010, 04:22 PM »
Offline stevochb
« Reply #19 on: February 17, 2010, 05:55 PM »
Nice work  :coolsmiley:
PK6061
« Reply #20 on: February 18, 2010, 08:40 PM »
fookin mint that bud :daumenhoch:
