975623
Dannygee
June 25, 2024, 07:58 AM
inner brake cable
Topic: inner brake cable (Read 778 times)
Gish
540 Air
who the fook are you lookin at !!!!
inner brake cable
February 12, 2010, 08:16 PM »
just wondering whats best for inner brake cable when threading through outer cable to prevent friction. is it grease or oil ? as i will be using this on a pitbull brake caliper
Ride it like its stolen
Bettyswallocks
Re: inner brake cable
February 12, 2010, 08:21 PM »
Bit of grease wiped on the inner before you thread it through
And if its for a rider use a linear cable, the outer cable wont compress like an old one will...
Gish
540 Air
February 12, 2010, 08:38 PM »
is a linear cable the outer cable with plastic inside it
HEYWOOD BMX
February 12, 2010, 08:45 PM »
Linear cable housing is straight whereas regular cables are coiled.A lot of cables these days are also slic type-they have a teflon impregnated plastic tube for the inner wire to pass through...
subversion
February 13, 2010, 12:35 PM »
stick to a lighter, thinner grease & you can always put some oil down the outer first too...
inner brake cable
