975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 26, 2024, 11:24 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  mk 1 tuff 2 hub help
Author Topic: mk 1 tuff 2 hub help  (Read 916 times)
winnit93
« on: January 30, 2010, 10:15 PM »
ive aquired these lovely little steel hubbed mark 1 tuff 2's but as ive never had tuffs this old im not sure which freewheel and clip i need
ginny has quite a few but thought id ask here
also front has had the studs modified but is there a better kit or someone on here that could do a better job
thanks in advance!
Re: mk 1 tuff 2 hub help
« Reply #1 on: January 30, 2010, 11:47 PM »
You will need a 16 tooth cog , they are the same as the ones found on the old sturmly archer three speed hubs , you will also need the locking ring to hold it on . If you have trouble finding them at your LBS drop me a mail as my LBS has them in stock . The screw bolty type things in the front wheel are skyway hub repair originals  if i am not mistaken , hope this helps .  :)
« Reply #2 on: January 31, 2010, 03:32 AM »
Not the same as a Sturmey Archer I'm afraid they are only a three spline sprokect, that is an early cassette hub with considerably more splines.  You'll also need a lock ring for it too.  I think it's the Suntour type like this:
But I think unless someone else has one of this type it's going to be a bit hit and miss to find what you need.
The Front hub is a replacement Skyway og kit, you could replace the nut and bolts with domed ones from b&q or somewhere but then it won't be og anymore  ;)
« Last Edit: January 31, 2010, 03:33 AM by MartyC »
daz bmx it!
« Reply #3 on: January 31, 2010, 09:07 AM »
I think BrianP on here may have a spare? give him a pm he helped me out :daumenhoch:
« Reply #4 on: January 31, 2010, 09:17 AM »
the spring clip is a right fooker to find scoot, it might be worth spen getting you one and trying it, cos if he has a lead on em it will help alot of people out
neiljonarcus
« Reply #5 on: January 31, 2010, 09:18 AM »
i am going into the shed today i am sure i have one on a old hub if so its yours
neiljonarcus
« Reply #6 on: January 31, 2010, 09:57 AM »
scott you are in luck mate both ring and clip  i will send it over just payme the postage  :)
   postage  £ 79.63
 :LolLolLolLol: :LolLolLolLol: :LolLolLolLol:    only kiddin you know the cracke mate
Offline WARDY
« Reply #7 on: January 31, 2010, 10:04 AM »
   postage  £ 79.63
 :LolLolLolLol:  good on ya Neil :daumenhoch:
« Reply #8 on: January 31, 2010, 10:27 AM »
That Geordie fooka charged my 82.47 last time he posted sommat to me....... :LolLolLolLol:
Morning fellas - I'm guessing my brother logged on as me last night the numpty or I was more drunk than I remember as I know fook all about these sprockets but he does :crazy2:
Spen
« Reply #9 on: January 31, 2010, 10:31 AM »
Spen
Who are you?  Shaggy? It wasn't me....  :LolLolLolLol:
Think the post worked a treat though and but the looks of it scotty has the right sprocket  :daumenhoch:
