975807 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 03:53 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Plastic welding
Author Topic: Plastic welding  (Read 917 times)
DY85262
Plastic welding
« on: January 30, 2010, 10:42 AM »
Ok over to you pros that work with plastic.
Is there anything I can do to weld my plastic number plate.
Well over the past 25 years it went kinda brittle and my plate keeper tried to bend the top straps around and they snapped.
Its like the Haro circuit board at the top.
Can it be plastic welded or a hot glue gun type thing used?
Sure it may go in another place but if I heat the plastic when bending it may help?
I guess I am thinking about the repairs done to car bumpers and motorcycle plastics.
Offline DIRTBIKER250F
  • Home sweet home
Re: Plastic welding
« Reply #1 on: January 30, 2010, 10:44 AM »
Would a good Glue not do the Job ?
neiljonarcus
Re: Plastic welding
« Reply #2 on: January 30, 2010, 11:04 AM »
would glue not do the job
DY85262
Re: Plastic welding
« Reply #3 on: January 30, 2010, 11:12 AM »
I doubt it. the force needed to bend that plastic will result in that seperating. Maybe a hot glue would do the trick. But again I am dubious. I have heard of welding and wondered if anyone had tried it out of teh BMX world we live in  :)
Good morning to Poole for me today. I do miss it being all the way up in Scotland  :)
neiljonarcus
Re: Plastic welding
« Reply #4 on: January 30, 2010, 11:22 AM »
what about buying a new one
Offline GTnumber1
Re: Plastic welding
« Reply #5 on: January 30, 2010, 11:27 AM »
try using a gas solder iron i repaired many a plastic trims on cars at work  :2funny: it may work   :daumenhoch:
monkian
Re: Plastic welding
« Reply #6 on: January 30, 2010, 11:31 AM »
Some welds go brittle depending on the type of plastic.
You might want to get some shavings off the item you want to weld and test it first :daumenhoch:
DY85262
Re: Plastic welding
« Reply #7 on: January 30, 2010, 11:35 AM »
Ohh if you could please find me one. I have never ever ever seen another.
Wizard USA , somethig panel..... I think it says supa panel on the bits that wrap around the side
This was my OG plate so kinda feel attached too.
Just seen other replies. Good ideas. Cheers
etriedes
Re: Plastic welding
« Reply #8 on: February 05, 2010, 10:34 PM »
They use hot air guns to weld plastic ...  you could hire one from a tool hire shop, or if you know someone who does hard flooring, they use the same equipment .. i'd practise on something similiar first, they get very hot very quick ..
Offline diesel
Re: Plastic welding
« Reply #9 on: February 06, 2010, 08:13 AM »
Some specialist motorcycle shops do plastic welding on fairings - As they're soo expensive to replace them
DY85262
Re: Plastic welding
« Reply #10 on: February 06, 2010, 01:24 PM »
Now we're talking.
I will trawel teh web.
Cheers Guys
 :daumenhoch: :daumenhoch:
