975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 05:06 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  safe decal removal
Author Topic: safe decal removal  (Read 2014 times)
Glen
safe decal removal
« on: January 30, 2010, 02:26 AM »
is there a way to remove decals keeping them nice and re-applying them later?  I seem to remember something like this.  Thanks
firebird4130
Re: safe decal removal
« Reply #1 on: January 30, 2010, 02:27 AM »
I think heat from a hairdryer does it
neiljonarcus
« Reply #2 on: January 30, 2010, 05:17 AM »
if you use heat it will leave the glue behind so leaving you with baldy decals and also might shrink them ......try a realy hot cloth and a one side stanley blade if you use your finger nail it will crimp the coener of the decal
« Reply #3 on: January 30, 2010, 09:55 AM »
as n2cus said the hairdryer gets them off a treat but as you gently pull them up they go that soft they distort and go outa shape :-\ also the glue comes off. ask del he may give you a few tips. he was telling me about lighter fluid for removing them or something ( as he has to remove some intact to scan them )  :daumenhoch:
« Reply #4 on: January 30, 2010, 10:09 AM »
grinder :daumenhoch: they go back on exactly the same condish as they came off :LolLolLolLol:
neiljonarcus
« Reply #5 on: January 30, 2010, 11:06 AM »
would a grinder not break the decals a little bit  :)
Offline Rombloke
  • do one
« Reply #6 on: January 30, 2010, 06:11 PM »
ive tried and tried, always ended up rippin the cnuts off in temper
Dave
haro, how do you do
« Reply #7 on: January 30, 2010, 08:08 PM »
big fookin hammer :D
ive tried using all the tips off here and still not managed to do it without wrecking it
Offline Del
  • Re-living my youth!
« Reply #8 on: January 30, 2010, 08:11 PM »
you wont get old decals offand be able to retain the adhesive.
Its possible for freshly applied decals but not ones that have been fitted for a white.
monkian
« Reply #9 on: January 30, 2010, 08:16 PM »
This is a good lil' tool (I told her but she didn't believe me) :'(
http://www.kk.org/cooltools/archives/000915.php
http://lilchizler.com/
« Reply #10 on: January 31, 2010, 09:32 AM »
if only i had some decals to put on my bike  wow, imagine, that would be awesome   ::) :LolLolLolLol: :daumenhoch:
Offline oldschoolrb
  • im all goosed out
« Reply #11 on: January 31, 2010, 09:48 AM »
so with a heat gun/ hair dryer/ somthing hot or  blow's hot air , could remove them in good tact but leaves them with no sticky on them ? is this right ?
or will they srink/ streach distort in some way  ???
