975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 10:48 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  crank,chain ring alignment ?
Author Topic: crank,chain ring alignment ?  (Read 539 times)
steveb
« on: January 29, 2010, 09:00 PM »
 ???     i have a felt sector cruiser and have changed the stock gearing. the std chainring had a reducer/spacer fitted. when fitting the new chainring it was already at 19mm so i am presuming i will need spacers ?  is there a way of measuring the correct amount of spacing or is it trial and error? any help or diagrams much appreciated. thanx steve.
HEYWOOD BMX
Re: crank,chain ring alignment ?
« Reply #1 on: January 29, 2010, 09:06 PM »
 :) Pretty much trial and error.Try adding/removing spacers on the drive side of the bb until you get a better alignment.You can also get spacers to go behind the cassette/freewheel cog if that needs bringing out a bit...
steveb
« Reply #2 on: January 29, 2010, 09:57 PM »
thankyou for that,is it worth measuring the amount of axel to make it exactly central or is it good enough by eye ?  last time i did all this it was a 1 piece solid crank with a spider so none of this faffing around !!!!!!!! seems a strange design to have a floating axel that is not centred ??
HEYWOOD BMX
« Reply #3 on: January 29, 2010, 10:12 PM »
 Never heard of measuring the axle is centred.A floating axle can be pretty useful as you get plenty of adjustability.No good having a centred spindle if the rear sprocket is a bit+/- :daumenhoch: I`m running a 3 pc on my bike and the alignment is perfect with no tight spots at all.
