975808 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 06:53 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Seat post sizes????
Author Topic: Seat post sizes????  (Read 724 times)
bmxboy70
Seat post sizes????
« on: January 20, 2010, 09:21 PM »
Ok guys and girls what sizes do seat posts come in? I have measured mine and it appears to be 23mm. The post I have is 22mm which I thought most are? Anyway are there posts that are 23mm or just below??? and has anyone got anything??
Thanks in advance Si. :daumenhoch:
bmxboy70
Re: Seat post sizes????
« Reply #1 on: January 20, 2010, 09:42 PM »
Thanks for that! the post i have has a knurled bit on it and that holds ok but then the seat is way to high for racing?? I suppose I could cut it?
Offline James Nada
« Reply #2 on: January 20, 2010, 10:02 PM »
Simon,
Is it the Bully you're having trouble with?
Just a thought, but is it the seat clamp that's the problem rather than the post?
« Last Edit: January 20, 2010, 10:22 PM by James Nada »
bmxboy70
« Reply #3 on: January 21, 2010, 04:25 PM »
Yes it is the bully, but the clamps ok the post is only 22mm apart from the knurled bit which is 22.2mm so when I put it low for racing I don't like the way it clamps it bends the bolt! If I tighten on the knurled bit its fine but the seats to far up. After Karate I will do some pics! Anyway whats going on with the race is it on off or are we going somewhere else?? I'm up for anything just say the word! even a practice sess with the bmx boys!
bmxboy70
« Reply #4 on: January 21, 2010, 04:37 PM »
Just use a shim around the post.  Cut a piece of coke can about 4 x 2cms,  works perfectly
Good thinking!!
