975836 Posts in 138948 Topics by 6376 Members - Latest Member: The Carrot Cruncher January 09, 2025, 05:23 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  how to get odi mushrooms of a set of bars
Author Topic: how to get odi mushrooms of a set of bars  (Read 569 times)
donnydresser
« on: January 18, 2010, 01:30 PM »
hi guys and gals   does any one  know of a way to get grips of bars  without damaging them.ive tried for a couple of hours and ended up wi a sore back :LolLolLolLol: thanks for any help kev
Re: how to get odi mushrooms of a set of bars
« Reply #1 on: January 18, 2010, 01:32 PM »
carefully lift the grip a touch from the bars and spray some wd40 down  ( the small cans come with an applicator straw if you still havin probs use this ) careful with them as they can split those odi's
Offline Jon The Bassist
« Reply #2 on: January 18, 2010, 01:33 PM »
lift up as much as you can and work a bit of washing-up liquid under, then twist it around until the washing up liquid gets everywhere under the grip.
dannywhiteley
« Reply #3 on: January 18, 2010, 01:41 PM »
I took some off this weekend when I swapped the bars on my TA.  Very carefully take a small screwdriver and ease it down the end of the grip to open up a small opening in which you can push the WD40 straw.  Push the straw down as far as you can and spray the WD in and sort of squeeze the grips to try to move the WD round in between the grip and the bar.
The grip should start to release and as soon as it does it will easily slide off the bars.  You have no chance of pulling them straight off.  Just keep adding more WD if its proving difficult.  Eventually they will just slide off.
Just be careful with the screwdriver when pushing it under the grip.  Ive done it loads of times and never damages the grips or scratched the bars.
Offline wildon
« Reply #4 on: January 18, 2010, 01:42 PM »
I went and got myself an insulin syringe ... the needle is mega mega small .. squirt in some soapy water in 2-3 locations around the grip and it comes off straight away .. you cant see any holes, especially if you put it in on the edge of the pattern
Offline Bigfrawg
« Reply #5 on: January 18, 2010, 01:50 PM »
carefully push a chopstick down the grip then use fairy liquid , same technique as the screwdriver method but without the damage  :daumenhoch:
Offline Zippy
« Reply #6 on: January 18, 2010, 01:50 PM »
Stanley knife straight throught the fcukers.  :LolLolLolLol:
Offline MaD-RoK
« Reply #7 on: January 18, 2010, 02:08 PM »
I take it you couldn't be arshed to type out your footpump method Si?  :D ;D :D ;D
Offline Why isnt this working
« Reply #8 on: January 18, 2010, 02:09 PM »
Chainsaw.
dannywhiteley
« Reply #9 on: January 18, 2010, 02:28 PM »
Next time I go for a chinese i'm swiping a few... :4_17_5: :LolLolLolLol:
I recently bought a bike that I broke for parts and the grips were just cheap yellow mushroom copies that were rotten.  It was just a joy just to take a knife to them, rather than piss about with WD40... :)
Offline Zippy
« Reply #10 on: January 18, 2010, 02:44 PM »
Right on a more serious note here's how you do it.
Safest way to remove grips with no hassle and zero chance of damaging the grips or bars is to use a bicycle pump with one of those little yellow plastic cone adaptors.
Simply attach the adaptor to the end of the pump
[/img]
and place the adaptor into the end of the grip where the little hole is.
[/img]
Now place your finger over the other hole and and start pumping.
[/img]
If you've done it right the grip will slide off with zero effort. Now do the same on the other grip but this time place your hand over the end of the bar itself. Again the grip will simply slide off.
Easy peasy.
« Last Edit: January 18, 2010, 02:47 PM by Zippy »
Offline 20to26
« Reply #11 on: January 18, 2010, 03:05 PM »
alternatively you can put boiling water in a tall cup/mug/travel mug and insert the grip/bars into the water...
Soak for a mo then extract from the water...
and pull the grips off with a gloved hand (cos the grip is gonna be hot)
« Reply #12 on: January 18, 2010, 05:02 PM »
i like si's idea with the pump.
might try that in a min just for the sake of it  :D.
trouble is mushys aint got a hole in the end. so the wd40 is the way to go.
