975755 Posts in 138933 Topics by 6360 Members - Latest Member: TattooedYorkie September 22, 2024, 12:00 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  fing 3 piece cranks
Author Topic: fing 3 piece cranks  (Read 720 times)
motomagII
fing 3 piece cranks
« on: January 07, 2010, 08:45 PM »
i have just fitted set 3 piece cranks usa unsealed bb set with square taper bb set .with 175mm fsa arms fixed spider and fsa chainring.basically it is near on impossible to get the chainring aligned right with the rear freewheel.
there is a bobble on the axle drive side which the bearing cone tightens to this has to be tight or will work loose ,so no scope for movement here
this goes into the cups and on goes the other cone non drive side lockring and washer .basically there dont seem to be any way of adjusting one way or another at all here.then i fit the crank arm drive side and it looks way too far out by about 5 mill ,so removed and fitted washer between spider and chainring to move the chainring inwards little bit but still way out of line .arm is tight as feck too onto the sqaure axle .
given up now and pissed with it .
HEYWOOD BMX
Re: fing 3 piece cranks
« Reply #1 on: January 07, 2010, 09:26 PM »
 :) Aside from the other probs,is it a BMX specific crankset? Some road/MTB cranksets with fixed spiders have a different chainline to BMX & refuse to play ball... :daumenhoch:
« Reply #2 on: January 07, 2010, 10:03 PM »
try turning the spindle round Greg :daumenhoch:
motomagII
« Reply #3 on: January 08, 2010, 04:44 PM »
turned the axle round and wasnt much better but was biut closer
was sold as bmx bb set
anyone measure length of bmx specific axle length for me please to check it out
« Reply #4 on: January 08, 2010, 04:53 PM »
I think it's 127mm  :daumenhoch:
