975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 30, 2024, 02:25 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  ISIS Type BB removal help
Author Topic: ISIS Type BB removal help  (Read 853 times)
Offline Haro82
« on: December 31, 2009, 01:24 PM »
I'm trying to get the BB out of my daughters redline race bike. It's an ISIS type but my removal tool has not got a bigger enough diameter to go over the spindle, I've looked at others and they all look the same. Any ideas on what tool I need ?
Here's some pics :-
lodge
Re: ISIS Type BB removal help
« Reply #1 on: December 31, 2009, 02:03 PM »
Is that ring thats preventing the tool going on not removable? try pricing it off if it is? is the other side the same? you may have to take the other cup out and drive the axle out.
Offline Haro82
« Reply #2 on: December 31, 2009, 02:53 PM »
I knew the ring was stopping it and having just posted the pics up it does look like it might come off  :-\ I thought it was all one.  It's the same on both sides. I will have another look to see if it does prise off  :daumenhoch:
Offline Dingobmxer
« Reply #3 on: December 31, 2009, 02:53 PM »
You need the correct tool, The one you have is for a square taper spindle/BB I think?
Dingo
Offline billstup
« Reply #4 on: December 31, 2009, 03:06 PM »
It looks like the axle has moved through the bearings a bit, try giving it a tap and see if you can move it back so that the ring is right up agaist the bearings then the tool should go in ok, and don`t forget that the non drive side, or left hand side, is a left hand thread  :daumenhoch:
Offline Haro82
« Reply #5 on: December 31, 2009, 03:17 PM »
That ring was removable  :-[  I got it off and managed to tap the tool on and it's now off  :daumenhoch:
Cheers chaps for your replies  :)
