975755
TattooedYorkie
September 21, 2024, 03:41 PM
rear bullseye hub dimensions
Topic: rear bullseye hub dimensions (Read 1105 times)
Donker
March 21, 2006, 09:37 PM »
due to not finding a decent (cheap!) rear sealed suzue or bullseye hub, im gona make a rear to match my front bullseye.
i need to know if the rear outside diameters are the same as the front, and also the lengths of centre section and overall length.
any help mucho appreciated
cheers
sawzall
540 Air
Re: rear bullseye hub dimensions
March 21, 2006, 09:43 PM »
hi donker are you going to epic? i have an old bullseye rear hub if you want to borrow it you are more than welcome
sawzall
540 Air
March 21, 2006, 10:07 PM »
just found hub, measurements are as follows
o/d flange to flange=64mm
o/d flange to thread=80mm overall length
i/d flange to flange=57mm
inner hub to step up= 42mm
step up= 15mm
hope this helps if you want to borrow hub just let me know cheers phil
Donker
March 21, 2006, 10:22 PM »
not going to epic mate but ill have a go with those dimensions. could you post a picture with the dimensions on it please?
thanks
sawzall
540 Air
March 22, 2006, 09:14 PM »
hi donker pm me your address and i will pop it the post so you can borrow it if this will be easier,
Donker
March 22, 2006, 09:30 PM »
pm sent mate, thanks very much.
