975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 02:45 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  What brakes?!!!
Author Topic: What brakes?!!!  (Read 604 times)
robrffr
What brakes?!!!
« on: December 15, 2009, 08:11 PM »
Ok, my ride has no front brake and the back one is naff!! Also the cable is abit short, so not too good on right hand turns!! So what's good that I can pick up cheap?!!! The front forks are mongoose, got two stubs sticking out, so take it thats for a U brake?
robrffr
Re: What brakes?!!!
« Reply #1 on: December 15, 2009, 08:26 PM »
Ok, so any u brake will fit the forks will it?!! I so much prefer motorbikes, i know about them!!! ;D
Re: What brakes?!!!
« Reply #2 on: December 15, 2009, 08:32 PM »
Rob, if you need any help setting then up mate just let me know.........i'm only round the corner  :daumenhoch:
if you do it yourself then make sure you take the inner cable out and spray a good load of WD40 down the cable outer before you set them up  :daumenhoch:
robrffr
Re: What brakes?!!!
« Reply #3 on: December 15, 2009, 08:34 PM »
Cheers Glen, and Pickle, once I get some, I'll give you a shout mate, cheers :daumenhoch:
Re: What brakes?!!!
« Reply #4 on: December 15, 2009, 08:36 PM »
no probs mate......i don't have any old ones knocking about otherwise i'd throw em your way  :-\
