975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 12:02 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Brakes
Author Topic: Brakes  (Read 967 times)
adam68
Brakes
« on: December 13, 2009, 05:52 PM »
Can anyone tell me wot are the best old school brakes to use. There for my 85 sterrt beat. The ones on there at the moment are crap :daumenhoch: I want to use it a bit more but dont want to die  :LolLolLolLol: :LolLolLolLol:
Offline DIRTBIKER250F
  • Home sweet home
Re: Brakes
« Reply #1 on: December 13, 2009, 06:04 PM »
Check my for sales thread in the for sale threads, nice pitbull  :daumenhoch:
Offline rooski
  • Mons Veneris
Re: Brakes
« Reply #2 on: December 13, 2009, 08:05 PM »
get plenty lube in the cable, make a big difference :daumenhoch:
nosepickben
Re: Brakes
« Reply #3 on: December 13, 2009, 09:12 PM »
Yeah lube everything properly, boa or nippon up front, put a bit of extra spring on a nippon by disconnecting the thick wire spring and ragging it outwards a bit before refitting, shouldn't need to do that to a boa. AD990 if lugged or a pitbull if not for the rear. Pitbulls can be buggers to set up, don't really know why, such simple things really. Keep cable line as straight to it as poss + use trial and error with blocks... Good luck!
Offline Wadz
  • Ride Ride Ride!!
Re: Brakes
« Reply #4 on: December 13, 2009, 10:39 PM »
i used dc 901's at first on mine, work spot on when set up correctly, only thing is you cant spin bars , then had dc bulldogs with gyro( couldnt get enough brake pressure)
now ive got acs boa's and asc rotor ( smooth as and they work a treat)
Offline Bigfrawg
Re: Brakes
« Reply #5 on: December 14, 2009, 09:56 AM »
nothing wrong with mx 1000's if set up right but i would definately use clear sticky pads though , they will stop anything ! not old school but they sure do work  :daumenhoch:
adam68
Re: Brakes
« Reply #6 on: December 14, 2009, 10:49 AM »
Good call will try them :daumenhoch:
Re: Brakes
« Reply #7 on: December 14, 2009, 11:22 AM »
mx 900s are the better caliper, less flex, more bite :daumenhoch:
